03-19-2015 05:42 PM
03-20-2015 10:50 AM
To clarify somewhat (I'm working on the project with Nick), there's a top-level sequence that calls a subsequence A, that calls a subsequence B, that calls a subsequence C. In the report, we see that subsequence B shows that the execution of subsequence C passed, but there are no results in the report that show the steps within subsequence C.
We're using the standard NI sequential process model with no callback overrides, and the ATML report format.
Here's an interesting thing: I looked at the execution of the system yesterday for a short time, and turned on "on the fly" reporting. I paused before subsequence C started, then single-stepped through subsequence C, and saw the report being populated with all of the steps. Unfortunately, the process model crapped out at the end when it tried to create the report (said the report file already existed - I don't mind so much about this, as I don't really want to use on-the-fly reporting anyway).
Hey Nick: whcih version of TestStand are we using?
03-20-2015 11:05 AM
We are using TestStand 2013 (v 5.1.0.226)
03-20-2015 06:16 PM
Hi Nick,
I've tried to replicate this on my end and am not seeing the same behavior. Do you mind posting the sequence you have the displays this behavior on the forum?
03-23-2015 08:21 AM
Make sure that you did not disable result recording on the sequence call step which calls sequence C.
Hope this helps,
-Doug
03-30-2015 01:52 PM
Carli,
See the attached *.piz folder for the problematic code.
03-30-2015 02:01 PM
I don't *think* we did, I checked the sequence and subsequence settings and didn't see anything untoward...
