04-07-2015 09:12 AM
Hi guys,
I feel as though this probably isn't a big deal to implement but I'm still somewhat new to teststand and hope you can help. I am currently printing a label on passing UUTs which include:
1. Product part number
2. Product serial number
3. Test date and time
To do this I am calling a labview VI to handle this and passing the parameters. However, now I need to implement a label that is printed when the UUT fails. The information needed is the three above items as well as the addition of the name of the failing step(s).
How can I go about getting the n ame of the failing step(s) to pass it to a VI to print a label? Also, would the use of a callback make sense in a case like this?
Thanks in advance.
04-07-2015 09:35 AM
I have done a little digging and it seems as though a SequenceFilePostStepFailure callback could work here. I created a FileGlobal string that is updated with Parameters.Step.Name when the step fails which is great. However, if that step is in a subsequence then the step name is overwritten by the subsequence name when you exit the subsequence. Is there a way around this to either only grab the step name and/or the subsequence name depending on your preference?
04-08-2015 04:09 AM
I have attached a sequence which stores the failure names of all failed steps except sequence call.
Check file globals.FailureStr which contains all the step names.
Hope this helps.
Ravi
04-08-2015 10:25 AM
Hi Ravi,
This is great! Nice solution. Thank you very much.
I have one other question to add to this I'm hoping you may be able to help with.
I have many sequences that this change would need to be implemented in. From my reading it seems as though in a case like this it would make more sense to add this change to the process model. To do this, would you just add this callback in the process model itself? The other piece of this is it seems as though the process model has its own FileGlobals. What is the way to pass these between the process model and the sequence?
Thanks again.
04-09-2015 12:46 AM
In this particular case i have used a engine callback and not process model callback.
Refer this :
http://www.ni.com/white-paper/6605/en/
So you need to use engine callback modifiations i.e.
http://zone.ni.com/reference/en-XX/help/370052K-01/tsfundamentals/infotopics/callbacks_engine/
Open "C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\Components\Callbacks\Station\StationCallbacks.Seq" and modify as per attached file.
You will need to use stationglobals instead of fileglobals.
Hope this helps,
Ravi
