NI TestStand
Adding UUT.PartNumber to the text report file name
I need to add the UUT.PartNumber to the text report file name. I am using TestStand 2012 with the sequential model, and the report format is text.
Is there a way to do it from the Reports Options dialog in the Result Processing configurator or should I do it within the model?
Yannick
(4,140 Views)
Hey Yannick,
You can do this from the Report Options dialog. I actually posted something a while back about doing this. See here: http://forums.ni.com/t5/NI-TestStand/TestStand-2012-Change-the-UUT-data-type-now-contains-a-new-quot...
I hope that helps, and let us know if you run into any more questions about it!
(4,137 Views)
