08-18-2014 01:21 AM
Hi All,
I use sequence editor TS 2013
How can I add the module time value of the step on the report jdocument?
Tnx,
08-18-2014 02:24 AM
In the report options, check the option "Include Execution Times".
Norbert
08-18-2014 02:45 AM
Hi Norbert,
The execution times checkbox is marked and has no effect on step module time.
I think it related to the total execution time of the sequence and doesn't for the module time of the step.
The report shows me only :step name,status,measurment,units,limits and comparison type.
Tnx,
08-18-2014 03:59 AM
There is only a valid time if the step includes a code module written in an external language. There won't be numbers in steps using pure TS functionality (e.g. statements).
Please tell us what kind of step you are using and post an image of the report. Also you should describe/post image of your report settings.
You didn't modify the report plug-in, did you?
Norbert
08-18-2014 05:37 AM - edited 08-18-2014 05:48 AM
Execution time is displayed for all report formats except when using horizontal stylesheet in XML and ATML report. If you want to see execution time in XML or ATML reports, change the stylesheet.
What report format are you trying to create?
Did you try with other stylesheets and other report formats?
- Shashidhar
08-18-2014 06:58 AM
Hi Norbert,
Please find attached file
Hope it understandable,
Tnx
08-18-2014 07:04 AM
The snapshots inside your attachment specifies that you are using ATML5 report with tr5_horizontal.xsl stylesheet.
Modify the stylesheet to tr5_report.xsl or tr5_expand.xsl to view the execution time in report.
- Shashidhar
08-18-2014 07:09 AM
Hi Shashidhar,
it works fine,
thank you
