Hi Jack,
Is there a more specific error message or error code to go along with
that? Are you using one of the NI Operator Interfaces to run your
sequences or are you using the Sequence editor for debugging?
Pretty much all of the Operator Interface uses ActiveX, it is the main
component that allows other languages to communicate with TestStand.
What are your code modules doing? Is there any interaction with
software other than TestStand? Do the VIs work if run outside of
TestStand for an extended period of time?
Let us know and we'll get it figured out. Thanks Jack,
Dan Weiland
Dan Weiland
