11-16-2014 11:51 PM - edited 11-16-2014 11:53 PM
HI All
I am trying to build TS user interface in LabVIEW. I want to give ability to user to debug sequence while running.(ability to put breakpoint and view the value of variables in watch view window).
Can we access TS watch view window in LabVIEW .I did not find any activex control for it.
If not how can you give user ability to debug sequence?
Does anyone have idea about this?
11-17-2014 09:15 AM
Connect a TestStand UI ListBox Control to the TestStand UI ExecutionView Manager control using the ConnectCallStack method.
I believe that gives you a watch pane.
Hope this helps,
11-18-2014 12:13 AM
hi
I have tried using that.Call stack gives you option to view current execution from the list of executions.(Call stack in TS basically).
It does not give you watch view interface . 😞
Basically I want user to give option to debug sequence . So on the execution view control he should be able to put breakpoint and then once execution reaches breakpoint , he should be able tov view variables values by adding them in watch view pane.
any ideas how to do this?
11-18-2014 08:29 AM
My bad. I was confused. Unfortunately that control is not exposed like the others. Even if you did find it in one of the assemblies I'm not sure you can connect it like the other activex controls.
Sorry!
You can suggest it on the idea exchange. I think it would be great to have that ability in a UI.
11-20-2014 03:52 AM
Yes...I think it will be of great help to have that feature.
Meanwhile I have to now search for other options to meet my requirement.
Thanks for d help!!
