04-23-2013 07:06 PM
I'm able to parse the following step's Limits properties:
- High: [Step].AsPropertyObject.GetValNumber("Limits.Low", 0).ToString()
- Low: [Step].AsPropertyObject.GetValNumber("Limits.Low", 0).ToString()
- Comparision Type: [Step].AsPropertyObject().GetValString("Comp", 0)
Does anyone know what property to parse for the Units (ie degrees, rpm, mL, mm, etc..)?
TIA for your help.
04-24-2013 12:04 AM
The units are under the results.units
If you are using TS 2010 or above you can click on the step -(properties tab)- go to property browser and looks for the step.variables to know where they are.
04-24-2013 12:10 PM
I found it: [Step].AsPropertyObject().GetValString("Result.Units", 0)
