11-29-2016 07:52 AM
I am having this error message while calling an activex method using Microsoft Scripting Runtime 1.0 server. I use the method of Create Text file.
Actually if i enter filepath directly there's no problem but if i try to load to a variable from property loader it gives this error.
The interesting thing is it works on a similar system on a PC with similar configuration.
I am using TS 2016 on 64 bit Windows 7 Pro licenced PC
11-30-2016 08:59 AM
Have you noticed if this error happens with other ActiveX methods, or only the one in particular that you are trying to use, this error doesn't seem to have a lot of documentation and it doesn't seem to be an internal TestStand error, so it is possible that it is a problem with the ActiveX method itself or the location.
12-01-2016 01:48 AM
ok i solved it, it's a notation problem in the code but it should warn as syntax error as well
