01-15-2016 04:53 PM
Running TestStand 2013 and I also have LabView 2013 installed.
Running through some of the training exercises (Exercise 4) and I receive this error:
Error Code modules must be able to load General Module for Step 'Volume Label Test' not Loadable. Failed to load VI 'C:\Users\Public\Documents\National Instruments\TestStand 2013\Examples\TestStand 1Exercises\CD Test\Code Modules\Volume Information.vi' in the LabVIEW Run-Time Engine version '10.0.1f4'.
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>>Open to open the VI and then verify that you are able to run it.
VI Path: C:\Users\Public\Documents\National Instruments\TestStand 2013\Examples\TestStand 1Exercises\CD Test\Code Modules\Volume Information.vi CD Test.seq Seq["MainSequence"].Main["Volume Label Test"].TS.SData
The two subVIs that TS looks for when I investigate through the module tab in Step Settings:
Error Cluster From Error Code.vi
System Exec.vi
Not sure why TS does not find these subVIs
Fernando
01-18-2016 05:58 PM
Hello fhernandez,
Do you have any other version of LabVIEW installed? It seems like it is looking for LabVIEW 2010 runtime engine, while you have LabVIEW 2013
01-19-2016 02:18 PM
What is your LabVIEW adapter settings in TestStand? Sounds like you should use the Development Environment for this.
01-22-2016 08:32 AM
Hmm.. So I installed LV2010 and resolved the proble.
For some reason, I thought that VIs created in 2010 could be run using the 2013 run-time engine.
Thanks for the help!
Fernando
01-22-2016 09:06 AM
Hi Fernando,
A VI generally consists of two parts: the source code and the compiled code. The source code is generally portable from one LabVIEW development environment to the next one. The compiled code is however specific to a certain run-time version.
LV2010 VIs can be run in the 2013 development environment as the 2010 specific compiled code is being re-built for the 2013 run-time engine once you do this.
You can however not run a 2010 VI in the 2013 run-time-environment ... it needs to get re-built by the development environment first.
In your case you could have simply installed the 2010 run-time environment and it would have worked. You wouldn't have needed to install a complete development environment.
Best Regards
Mathis
01-30-2018 01:37 AM - edited 01-30-2018 01:39 AM
Hello, I'm obtaning the same error:
Module for Step 'Action' not Loadable. Failed to load VI 'C:\Users\\Desktop\TestStand\teststand.vi' in the 'LabVIEW Development System' version '17.0f2'. Unable to load VI 'teststand.vi' in 'LabVIEW Development System' because the VI is broken.
I developed my vi (in FPGA) in LabVIEW 2017 and my version of TestStand is 2016, is this the problmen?
