01-05-2006 09:07 AM
01-05-2006 09:24 AM
You shouldn't have to do what your are doing as in GetSubProps2.JPG, because the Close Reference function peforms normally even if an error occurs outside and before of the function.
Regards
Ray Farmer
01-05-2006 09:45 AM
Hi Ray,
I tried it and you are right. But this is new for me. Is there a difference to older LabView versions or to TestStand references? In the past I often had the problem that some activeX References were not be closed caused this..
But do you know, why merge error doesn't work? What is the difference?
Thanks TPoint
01-05-2006 10:45 AM
Hi TPoint,
It probably is working but it depends how big that error cluster is, it could be quite large, an you know what happens to labview an larger array of clusters can do, especially if they is no delay in a loop. Basically it grabs all the processor.
There was a problem, I think the change from labVIEW 5.x to labVIEW 6.0, (I think) which caused a problem in the LabVIEW Operator Interface. This was resolved by passing the reference through a shift register, as you have done with the error.
Now, I also do this with references.
Regards
Ray Farmer
01-05-2006 12:02 PM - edited 01-05-2006 12:02 PM
Message Edited by TPoint on 01-05-2006 07:06 PM
