It would be nice to integrate VeriStand into TestStand with a VeriStand Adapter.
This would make developing with TestStand and VeriStand much easier. The adapter would provide a lot of the VeriStand .Net api natively to testand:
- Deploy a system
- Set/Get Channel(s)
- Stimulus Profiles
- etc.
The adapter would be especially nice for integrating the new Stimulus Profiles in VeriStand 2011. It would allow for you to create the Stimulus Profile sequence and the Real-Time sequence. The Real-Time sequences would only be able to use a subset of TestStand steps, and would have to be different than a normal TestStand sequence because they are executed by the VeriStand engine, but the Stimulus Profile sequence could be a normal TestStand sequence.
The integration of the Stimulus Profiles would leverage a lot of features TestStand already has like source control, requirements, reporting, etc. Also, it would just give the user a much more intuitive experience when using the two together. Their test development would be centralized in TestStand instead of having to switch between the two different editors. It would also give better access to the parameters being passed into the Real-Time sequences at the TestStand level.
There are probably more benefits that could be realized by integrating TestStand and VeriStand, and this is a feature I would love to see as a user of both TestStand and VeriStand.
Good idea Kevin, maybe in the near future we will see something
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
