In TestStand you can create a comment in a variable, but that comment will be deleted even if the data type of the variable is changed. This does not make too much sense because it happens that the customer needs to change the data type, and then he has to re-write the comment completely. This feedback comes straight from multiple customers and it makes sense that it should be so.
Thank you everybody. Best,
Corrado
Fixed in TestStand 2017 under ID 656997.
