NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Using time string in report file path without space character
There are some macros to specify report file name by expression in report options.
Specifying Report File Paths by Expression - NI TestStand 2014 Help - National Instruments
http://zone.ni.com/reference/en-XX/help/370052N-01/tsref/infotopics/specifyreportfilepath_byexpressi...
$(FileDate) contains speces in the string, e.g., "2015 12 15". If you want to delete space, you need to use $(FileYear), $(FileMonth), and $(FileDate) instead.
But there is no similar expression for time, i. e., there is only $(FileTime) and we do not have any macro such as $(FileHour).
SearchAndReplace function doesn't work for the macros. It is very helpful if we have $(FileHour), $(FileMin), and $(FileSec) as standard macros.
Before:
After:
1 Comment
Active Participant Elaine_R.
I like this too, but I also want to plug an old Idea (self serving of me!) to just allow for arbitrary formats as single strings rather than complex expressions... as this would solve not only the white space issue but a host of others? Also, A.Sasaki, someone did answer mine with a .NET workaround if that helps you?
