NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
Support "Add Array Item" for Array of Structs in .NET code modules
Currently there is only the "Create type from struct" button available, when there is an parameter, that requires an array of structs, in a .NET call
What would be nice, is to have the features available, that are available when passing clusters to labview:
That is:
  • The Add Array Item button
  • The Delete/Delete All Item buttons
  • The feature of 'uncollapsing' a struct and setting the values for each field in the struct.
