NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
Support Unicode
Right now, you really can't reliably use anything other than a basic ASCII character set in TestStand, which means that some SI units (such as ohms) cannot be represented in their preferred way (with an omega).  It also means that you can't put non-english characters in your sequence file and reliably have them show up if your sequence file is opened on a different computer with a different language localization (which causes a huge problem if your customer demands support for non-English languages, and has more than one site -- that speaks a different language -- around the world).
Make TestStand support Unicode, so we can use the full greek character set for things like units, and so we can type characters from any language in our sequence files, and not have them change to a different character if we open them on a computer with a different localization.
