The Start Modal Dialog VI currently needs to be placed on the block diagram of the VI that needs to be modal. This means that you can't put it in a subVI with logic around it. If a VI reference input were added to the VI (with the default being the calling VI) then you could keep the same functionality but have the option of calling this from a subVI.
For those that are running into this, there used to be a workaround here:
Found the answer! This was already done in 2014! I was using 2013. I guess I had a really good idea, but NI was ahead of me 🙂 Anyway, on the DF link I posted, there is a solution if you are using 2013 or earlier as well.
