NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
snowpunter
Standardize Closing Of Tabs
Status: In Beta
by Active Participant snowpunter on ‎07-12-2012 02:59 PM
Current shortcuts for TestStand include Ctrl-D to close executions and Ctrl-F4 to close a sequence file. However, both of those windows show up as tabs in the current GUI layout.
Every modern internet browser allows the user to close a tab with Ctrl-W. This would also be a neat feature when only trying to close one report at a time when viewing the results from multiple UUTs, instead of closing all reports by closing all executions with Ctrl-D.
Status: In Beta
Comments
by Active Participant dug9000 on ‎07-16-2012 01:22 PM
Ctrl-F4 closes the active document window in the sequence editor, including execution windows, not just sequence files. Also you can change it to Ctrl+W if you want by customizing the keyboard shortcuts for the menu item. It is admittedly a bit misleading in that the menu item says "Close Sequence File 1", but it is really a special menu item that changes its caption based on the active document.
by Member Jimmy_Reumuth on ‎08-01-2012 03:38 PM
Every web browser I've seen closese a tab window with either Ctrl+W or Ctrl+F4. Ctrl+F4 is the standard windows hotkey to close the active document window. Many applications close the active window with Ctrl+F4 but not Ctrl+W, like Visual Studio for example.
by Member Lars_L on ‎08-20-2012 06:00 PM
Status changed to: Under Consideration
by Member Lars_L on ‎03-08-2013 03:01 PM
Status changed to: In Beta
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Idea Statuses
Top Kudoed Authors
User Kudos Count
14
12
7
5
3
