Do you ever write an expression in TestStand with a bunch of parenthesis () and get lost halfway through trying to figure out which pairs are open and which are closed. Well, I do. Every Day. And I spend accumulated hours a week just trying to keep track of which ) goes with which (. If I'm lucky I can look for a little red item in the expression, or click on the check expression checkbox, but when I have a 'only runtime evaluatable' expression I'm out of luck (which is rather often) ). Some languages/editors have a parenthesis matching, where the ) your cursor is on causes the matching ( to get bold or flash. Others start coloring each pair a different color, so it's easy to see them all. Why can't TestStand do something like this????
If you kudos this idea, can you please post which option you like better?
(Personally I like option 1 - show matching paranthesis only. Like Visual Studio, where they use a gray background)
Assuming that it's not in TestStand 2010, I'd prefer the matching brace highlighting. Having multiple colors could hide the error color (red by default), when the braces don't match.
The best option would be to allow the user to select one of the three options (none, match or colors) in the Expression Editing Options of the Station Options.
This feature has not been implemented. If you want to see it in a future version, you'll need to kudo it here.
I'd be ok with the instellisense version or the "basic" version from Notepad++
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
