When creating custom step types, it is highly recommended to use Post-Step for calling execution module instead of Default Module.
Thus, when instanciating a custom step type, parameters passing is not saved within the sequence but only in the step type definition.
This allows to change parameters passing without having to update all the step types instances.
In some big test benches, it is intersesting to have low-level step types and high step types based on low level step types.
High level step types execution modules are sequences using low level step types.
Since sequence adapter is not available for Post-Step, we are obliged to call the sequence through Default Module.
Thus it can generate problems when adding parameters in sequence call.
I suggess to allow Sequence Call in SubStep creation :
Jean-Louis Schricke, MESULOG
TestStand Architect
Jean-Louis SCHRICKE
├ CTA - Certified TestStand Architect (2008 - 2022)
├ CTD - Certified TestStand Developer (2004 & 2007)
└ CLD - Certified LabVIEW Developer (2003 & 2005)
