NI TestStand Idea Exchange
K_Joy
Put the X on the tab it goes with in the Sequence Editor.
Status: Completed
This is available in TestStand 2020
The current placement creates confusion about what you’re actually closing out of when you click it. It makes me hesitate and wonder what I am about to close.
If you click it when there are multiple files open, it just closes out of the tab on top. If you click it when there is only one file open, it closes out of the whole pane, including the Sequences and Variables windows.
It would eliminate any ambiguity if the X for each file were on the tab for that file and if there were a separate X for the pane, like you typically see in tabbed programs.
You could also just put an X next to the pin on each little window instead, like the X in the Step Settings pane and the Insertion Palette in the screenshot above.
11 Comments
warren_scott
And while you are updating the tab behavior, how about this:
if you have lots of extra space, why not go ahead and let the tab size get larger so we can see the full file name?
crossrulz
Knight of NI
I say emulate the tabbing effect of a web browser.  That means (at least with FF) that each tab has its own X.
GCentral
RavensFan
Knight of NI
That same idea is also in the LabWindows/CVI Exchange.
(Of course you know that since it was also your idea.)
Just to put a crosslink here so if someone sees one, they'll go kudo the other.
dug9000
NI Employee (retired)
I agree an 'x' on each tab would be nice. In the meantime, in case you aren't aware, in recent versions of TestStand (2013 at least and maybe 2012, I forget), you can middle-mouse click on a tab to close it (just like in most web browsers).
-Doug
sridar.m
Thats really needed when we work with many sequences
christopherdean
I didn't even know there was an "X" over there. I have always done a right-click, close tab. I think this is a good idea though, it makes more sense to put an X on the tab than way on the side.
paulmw
In web browsers I've accidently clicked on the 'x' and closed the tab when all I wanted to do was select it.  (Usually happens when I have two XML results files open and I am click back and forth to quickly see delta)
Any ideas to prevent this when concidering adding the 'x'?
Vincent90
Ctrl+W shortcut could do the job meanwhile NI implements it 🙂
bienieck
If you go to Configure >> UI Configuration you can uncheck Display Documents in Tabs. This way you can have it like this:
or
Then just keep in mind that if you maximize window and want to minimize it back, you have to find a black buttons (it is not intuitive IMO):
I'm just placing this comment here, because maybe you don't need tabs at all.
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
WireWeaver
Status changed to: Under Consideration
