NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
Provide mechanism to disable batch report through "Report Options" dialog box
The "Report Options" dialog box provides a lot of flexibilty in the way reports are generated for sequences executing under the Batch model.  A new report can be generated for each UUT, for each socket, etc.  One option that appears to be lacking, is to flat out not generate a Batch Report.  Doing a brief search, I found at two other folks who were trying to do the same thing:
http://forums.ni.com/t5/NI-TestStand/Disable-Batch-Report-TestStand-2014/td-p/3091476
http://forums.ni.com/t5/NI-TestStand/How-do-I-disable-batch-report-in-the-batch-model/td-p/238387
Suggest adding another check box to the Report File Pathname on the Report Options dialog box to disable batch reports.
