NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Programatically allow to select LV Adapter Development System version
Please make possible to select LV Development System version in similar way as it is possible to select Run-Time Engine.
It also should be available in TS API.
That will allow Test Engineers to use code modules (especially those inside .lvlibps) from different versions.
It would be also useful for to set up desired version of LV for code modules without lack of debugging options of Run-Time Engine calls.
