When a step cannot be preloaded due to the prototype being out of date (if, for example, a VI was updated after it had been placed in a sequence), an error message pops up telling the user what is wrong. This can then be used to track down where the step is that is causing the issue. Some of the error descriptions get quite lengthy.
While this does provide the user with information as to where the error is occuring, the only option is to click "OK", which then closes the message. In long sequences with many subsequence calls and steps (many of which may be similarily named), it is cumbersome to find the specific step that was listed in the error message that is now no longer viewable. At times I find myself having to get to the general area where I thought the error was listed as occuring, and then click RUN again just to get the error message to pop up again, and then continue narrowing it down (repeating this process several times). This is very cumbersome.
There is a simple solution to this issue. The easiest method would be to simply include a second button in the error message that brings you directly to the step that is causing the issue (with it selected in the step window). This would solve the main issue of trying to find the step that was listed in the error message as being the problem.
To go a step further, there could be a button that simply activates the "reload step prototype" that you have to do once you are at the step that is out of date.
To go even a step further, and solve another issue I would like to see remedied, there could be the option of reloading all steps that call that module (since they are now likely all out of date and need the prototype refreshed). Currently, if a VI is called repeated throughout the sequence, then each one must be found and have its prototype reloaded manually. This is very tedious.
There may be other preloading errors besides the "prototype out of date" issue (ex: VI not found, etc.) that could use the same functionality of a button that brings you to the offending step, but this is what I am running into at the moment.
Definitely in favor of a "take me to the step causing this error"
also would like to see the engine be able to give a "there are 14 steps that had errors preloading", and be able to list all of them and a "take me to this step" for each one.
To some extent this can be resolved with running sequence analyzer and it will give an error for the steps that have errors loading the module, and you can sort by that error type and easily get to each step.
To update all those problems in mass, the Tools -> Update VI Calls utility works great, especially if the VI prototype change is only cosmetic.
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
