NI TestStand Idea Exchange
GarryG
Pass Results Object to UUT Done Model Plugin Sequence
Status: New
Please pass the results object (as a Parameter) to the Model Plugin - UUT Done Sequence.  This would allow the remainder of the results processing since the last On-The-Fly result processing to be done only on that subset of the data (since, if OTF is enabled, the rest of the test has already been processed by the plugin).  There is no reason to have to recurse the entire MainSequence Results object and re-process all of the results for the entire test if this is passed and the processing is OTF.  As it stands currently, long delays at the end of a test can occur for intensive result processing algorithms (and large tests) because the entire set of results must be processed.
CLA, CTA
Not my tempo... AGAIN!
