NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
MichaelMC
PDF report generator for teststand
Status: New
by Member MichaelMC on ‎06-29-2011 07:50 AM
Why not make it possible for Teststand to generate reports in PDF format?
It would make it a lot easier to send a testreport of a specific board to people not connected to the actual tester.
Today we use XML but this requires the stylesheet to be present on the readers pc.
Graphs are also not showing correct unless you do a manual setup of the settings in Internet Explore.
PDF would make my life a lot simpler
/Michael
Comments
by Active Participant Josh_W on ‎06-29-2011 08:43 AM
I agree this might be a useful feature.
For the moment, the easiest way to do this is to use a free pdf printer (I use Bullzip PDF printer), and then print your report.  If you want to automatically do this during execution, you can use one of the programmatic printing examples:
http://zone.ni.com/devzone/cda/epd/p/id/5889
http://zone.ni.com/devzone/cda/epd/p/id/5890
by Member MichaelMC on ‎06-29-2011 08:53 AM
Thanks for your links to the examples, I will try it out.
Please don´t forget to give Kudos if you fing the idea usefull.
by Member pompapah on ‎07-03-2011 12:22 PM
Maybe I'm not reading this right - but why not just download a pdf generator from say Open Office?
or are you asking for a linked pdf generator off this site?
by Member MichaelMC on ‎07-05-2011 02:38 AM
No, I want to be able to choose PDF format for my report from within the "Configure Report Options" dialog.
by Active Participant dug9000 on ‎07-06-2011 09:56 AM
Have you tried using the xmlpack utility that comes with teststand? The purpose of xmlpack is to package up xml reports for redistributing them to others which sounds like what you are trying to do. I do agree that pdf would still be a nice option to have.
by Member MichaelMC on ‎08-01-2011 02:01 AM
No, haven't tried xmlpack. Sounds like it could help me for now, thanks!
by Active Participant crelf on ‎08-07-2011 09:38 PM
I'm not sure I understand what you mean by adding a PDF reporting option - PDF is a file format, not a formatting method.  So maybe what you want is to format your report using one of the existing methods, then saving it to a PDF file, right?
by Member MichaelMC on ‎08-08-2011 01:36 AM
I just want the report output to be a PDF file instead of a XML file.
by Member jpschoen on ‎09-06-2011 09:44 AM
Perhaps the PDF option should be in addition to the XML output. Other data collection systems may still need to access the XML files for data exchange while the PDF files are used for other reporting/sharing purposes.
by Member EMR on ‎10-13-2011 08:14 AM
what about a slight twist on the idea, where in report configuration tab not only do you (1)choose format (XML/HTML/TXT/ETC)
but you can also (2) choose to 'auto package on write'  i.e when making 'stand alone xml', have it go to a seperate folder WITH it's current stylesheet file (rather than having to go through the tools menu later). Or if user choses 'PDF' option, or 'to gif' or something of that nature. that way packaging can be turned on or off and will save a second file to a seperate location.
in your sequence all you'd have to do, if all you want is packaged files, would be to delete the original report file and only keep the 'packaged one'.  Sure, we can all do it by hand with freeware, but if we're all doing it, why not just build it in?... just my 2cents
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Idea Statuses
Top Kudoed Authors
