You can copy the value of a selected variable to another element.
But you cannot paste the value into the selected element in an easy manner.
What you have to do is click into the selected variable’s value field and then Paste, but this doesn’t produce the correct result (for strings anyway)......
You end up with is double quotes!!!
Also if you had ‘Copy Value’ on multiple selected elements and pasted them then you get
So it cannot handle multiple selections.
It would have been better if you could have selected the place where you wanted to paste the value(s) and a new menu item became available ie ‘Paste Value’.
This way should also be able to handle multiple selections.
The problem with double quotes shouldn’t occur and should be corrected with the current pasting of values.
Perfect for Drag-n-Drop Too![]()
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
