It looks like there is no "gentle" way to access the results of the executed tests in ongoing execution during this execution.
Sometimes there is a need to access the test results during the execution, before the data will be committed to the database, and execution is still ongoing. The reason for that could be we can reuse the some data of the test in other tests, or we can use for example the status of the test to drive the flow in our sequence.
It looks like there is no other general way to do that as only described by Sasha here: http://forums.ni.com/t5/NI-TestStand/RunState-ProcessModelClient-How-to-access-the-results-from-the/...
So, theoretically, - please read Sasha post - we have recipe to access all results we want. However, problem with accessing the result list is that, that it is done via the index of the ResultList array.
It leads us to two problems:
1. the elements in that list depends on the step position in the sequence file, which makes the editing sequence almost impossible,
2. if our sequence contain loops the problem from the point above is even more impossible.
Therefore, the idea:
Please prepare the easy accessible, not index based as it is now, method (container?) which developers can access the Results containers of the steps on the fly during the execution.
Handler proposal 1:
Step name (binded as unique ID) + execution order number
Handler proposal 2:
Callers path + StepName +execution order number
where execution order number could be the handler which could be number 0 by default unless the step is called few times.
Other post: https://forums.ni.com/t5/NI-TestStand/Accessing-measured-data-from-further-steps/td-p/1144710
