NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Josh_W
Make it easier to pass filenames as constant strings
Status: Completed
by Active Participant Josh_W ‎06-14-2010 12:50 PM - edited ‎06-14-2010 12:58 PM
How many times have you found yourself typing double backslashes "C:\\Windows\\System32\\cmd.exe" or even worse, going through a copied path to change every backslash to a double backslash (and inevitably missing one), just so you can pass a file or directory as a constant to a code module or another sequence?
I'd like to see a symbol for 'explicit string' in the TestStand expression language, much like C# does with the @ symbol.
So if we typed @"C:\windows\temp" we would actually get the string "C:\Windows\temp" instead of "C:\Windows<tab>emp".
To really go the extra mile on this:
  • Drag and drop could be enabled, so that any file dragged from another window into an expression box would automatically paste the filename.
  • A browse button could be added to the expression browse dialog which would bring up the usual file open dialog and insert the selected filename.
Message Edited by Josh W on 06-14-2010 12:57 PM
Message Edited by Josh W on 06-14-2010 12:58 PM
Status: Completed
With the release of TestStand 2012 you no longer need to escape backslashes in the path string. You can simply prefix the path string with the @ symbol to automatically escape the backslashes. For more details on this new feature, check out the "Expression Language Enhancements" section in the NI TestStand 2012 Help under What's New in TestStand>>TestStand 2012>>New Features. Thanks for the feedback! Lars
Comments
by Active Participant Jervin Justin on ‎04-15-2011 03:49 PM
Status changed to: Under Consideration
by Active Participant Al.B on ‎11-29-2011 10:50 PM
FYI - You can already acheive similar behavior using the Utility.Escape() method (credit to Doug), but I agree that a non-API method of doing this would be much easier and cleaner.
by Member Lars_L on ‎08-20-2012 05:05 PM
Status changed to: Completed
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Idea Statuses
Top Kudoed Authors
User Kudos Count
14
11
7
5
3
