NI TestStand Idea Exchange
flaborde
Intelligent Variable Creation
Status: New
The menu to create a new variable (right click on variable in an expression edit control and select Create "VariableName") contains all the data types you can use for the variable, however, in the LabVIEW Panel (and other similar panels or dialogs) there is enough context information about the variable to suggest a data type, for example, if the variable is in a control of type Double we know we should create a Numeric variable. TestStand should add the contextual suggestions to the top of the context menu and bold them so that I can more quickly select the data type I want most of the times, then have a separator and put the normal menu so if I don't want that data type for some reason I can still choose the other data types (see attached image).
