NI TestStand Idea Exchange
Eugene12
Include Configuration files, such as TestExec.ini by default in Deployment Utility
Status: Completed
We chose not to include this by default, but now there is a "From TestStand Configuration Directory" option on the source tab. If you check that box it will preselect the most relevant config files for you.
* Why not include Configuration files, such as TestExec.ini by default in Deployment Utility?
* Also using default settings, nothing appears in the Start Menu/All Programs menu on the target machine. Why not have the main sequence file to be installed so that it appears in the Start Menu/All Programs menu on the target machine?
Eugene
4 Comments
Eugene12
Member
Here is a link that indicates others have noticed this:
http://forums.ni.com/t5/NI-TestStand/StationGlobals-not-included-when-using-TestStand-Deployment/m-p...
Eugene
Eugene12
Member
How do I Include My Station Globals, Search Directories, Tools Menu, etc. in My Deployment When Using the TestStand Deployment Utility?
http://digital.ni.com/public.nsf/websearch/E5E4FEADEFE6023D862571590000C5CC?opendocument&Submitted&&...
Why is the default NOT to include these files??? Why would anyone ever generate a new deployment package using configuration settings that are not mostly the same as found on the development station?
Eugene
netsirk
NI Employee (retired)
Status changed to: In Beta
Kristen M
Automated Test Product Marketing Engineer
WireWeaver
Active Participant
Status changed to: Completed
https://www.linkedin.com/in/trentweaver
