NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
warren_scott
Improve error checking when connecting LabVIEW Clusters and TestStand Types
Status: Under Consideration
by Active Participant warren_scott on ‎06-20-2012 12:04 PM
Recently ran into a problem when I was configuring a LabVIEW module that passed in/out clusters/types.  I had a mistake in my code that the teststand data type was not configured to allow it to pass to LabVIEW clusters, but the problem was not as obvious as I thought it should be.
Here's what I had:
And when I click on the red checkmark "check expression" for "Cluster", it shows up as "No Errors".  Everything looks great, right?  Well, it isn't.
It's not until I expand "Cluster" to show the elements that I see that there are connectivity problems.
It would be nice if "Locals.mylocal" expression would turn RED and show a "check expression error" if any of it's children also had a connection problem (specifically in this case that the type in TestStand was not configured to allow passing to LabVIEW clusters).  This way it would be a lot easier to see.
Even worse, this problem is NOT found by sequence analyzer -- it's left to be found at runtime.
I know this is all because I had a bug/mistake in my code, but it would be a lot easier to track down and fix if these changes were made.
Comments
by Member Lars_L on ‎08-20-2012 06:01 PM
Status changed to: Under Consideration
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Idea Statuses
Top Kudoed Authors
User Kudos Count
14
11
7
5
3
