NI TestStand Idea Exchange
Eugene12
Cross-linking the wrong LabVIEW VI code modules
Status: Completed
There is often problems with cross-linking the wrong LabVIEW VI code modules. Why not automatically import VIs into TestStand from LabVIEW projects using the name of the LV project as a name extension for each VI in TestStand?
For example, if the name of the LV project is "Project 1.lvproj" and contains VIs named A.vi and B.VI, then these could easily be loaded into testStand as "A-Project 1.vi" and "B-Project 1.vi"?
Eugene
5 Comments
Eugene12
RayFarmer
Trusted Enthusiast
Eugene
Check out the following link, there is still time left
http://forums.ni.com/ni/board/message?board.id=330&thread.id=29209
Regards
Ray Farmer
Eugene12
Okay Ray,
I have now applied.
Eugene
Scott_Richardson
Status changed to: In Beta
Eugene - I am changing the status of this idea to 'beta'. The TestStand 2010 beta includes support for calling VIs in a project. You can sign up for the beta here: http://www.ni.com/beta. It would be most helpful to us to have LabVIEW users start experimenting with these changes and report back any issues or additional suggestions. Scott Richardson
Scott Richardson
Santiago D
NI Employee (retired)
Status changed to: Completed
