NI TestStand Idea Exchange
SachaE
Collapsible (collapsable) sections in the editor sequence view
So we have the setup, main and cleanup step groups in the sequence view which is fine, and they're collapsable which means if you're working in Main you don't get a screenfull of Setup above you.
We also have block sections that you can associate with step types to provide indentations making navigation easier.
What I'd like to see is the ability to create a collapsible section (so a sub sequence call is NOT what I'm talking about).
For times when a sub sequence call is not necessary, we should be able to insert a block section that is collapsable purely for visual appeal.
It makes long sequences easier to navigate. This would be a visual implementation modification on how we show block sections (so collapse versus indent).
Thoughts?
Sacha
// it takes almost no time to rate an answer Smiley Wink
1 Comment
Jervin Justin
NI Employee (retired)
Status changed to: Duplicate
Closing because this is duplicate to the following post: http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Folding-editor-for-control-flow/idi-p/1204367
Jervin Justin
NI TestStand Product Manager
