You can still access the name API property as follows:
Locals.AAA.AsPropertyObject.Name
The "API in expressions" feature was not in TestStand originally, and thus there are backwards compatibility implications if we were to either make it give precedence to API properties or to disallow using a name that conflicts with an API property. Thus the current behavior of TestStand is to give precedence to the subproperty when there's a conflict with an API property, and by using AsPropertyObject a user can still access the API property if needed.
I do think the AsPropertyObject workaround needs to be made more obvious though. It does not show up in the list when you type '.', but it does work.
