NI TestStand Idea Exchange
RayFarmer
Beable to pass parameters with the Sequence used in Post Actions
Status: New
When you set the Post Action On Pass | On Fail in a step to use Call sequence, the only ways to pass data to this sequence is either use some sort of Global (StationGlobals / FileGlobals) or use Locals with the setting "Propagate to SubSequence".
There should be a cleaner way and that is to beable to pass parameters as you do with SequenceCall step type.
regards
Ray Farmer
Regards
Ray Farmer
3 Comments
j_dodek
Hi Ray
I am just writting a step, where on passed a stuiped flag should be set. What i am doing is add a statement after
the step looking at prevoius status and set the flag. I am doing this stuipd stuff all the years. I remembered your idea here
so it was time to place a commend here because your ideas very good. If this in TS, i can get rid of a lot of statements, which nobody else understand why i have placed them, because they belong to the previous ones !
Regards
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Romain_Duval
I know the topic is old and related to 2010SP1 version but there is a simple way to workaround this limitation by using a wrapping, though it is not direct:
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
warren_scott
Yes you have access to something that is called locals, but those locals are local to the wrapper sequence, NOT the locals variables of the parent sequence the original step was in.  And you don't have (direct) access to the Step.* variables of the original step with the postaction.  You *might* be able to get around this by using RunState.Caller.*
