NI TestStand Idea Exchange
~jiggawax~
Allow Sequence Adapter to expand containers in the module tab
Status: New
I think it would be a great idea to allow the sequence adapter to expand containers like the CVI and LabVIEW adapters do when you are editing the module for the step.
See attachment.
jigg
CTA, CLA
testeract.com
26 Comments
SteenSchmidt
Trusted Enthusiast
Just ran into this yet again today, and was dumbfounded when I (re)remembered that this isn't a feature of TestStand (yet, hopefully).
Oh well, just one of those kludges we have to drag around to make TestStand dance to our beat...
But, for the love of God, please implement this feature.
/Steen
CLA, CTA, CLED & LabVIEW Champion
cous
We just ran into this while trying to pass data into a subSequence. This would be a very nice feature to have. As it is, we will have to use local variables within the subsequence to pass our data as opposed to using parameters, which would make more sense. Tally another vote for this feature.
Mirash
Please implement...
Spoiler
Coding is a combination of intelligent and creative work - someone
AustinManinTown
A student in my TestStand class asked about this exact feature. It is a great idea.
David C
SumitN
This would be a very helpful feature. I pass containers back and forth through sequence calls. I would be able to make the variables much cleaner if the containers were expandable. The sequence analyzer does not catch container mismatch, i.e if I edit the container later and forget to update the sub-sequence I am calling (since I pass the same contanier to multiple sub-sequences) then the sequence errors out during execution. I can catch these problems before finding them in production, if the container was expandable
Mr._Jim
Yes, please. I'm passing in a ton of parameters as options for my model plugin and I have to break them out individually as parameters, then set the typedef instance internally. (This is painful, especially if I have to add more options in the future)
DMD
Please implement...
RavensFan
Knight of NI
If you want it then click the Kudo Star to register your vote.  That is how the Idea Exchange works.  Kudoes are votes.  Just saying you want it implemented in a comment doesn't count.
Cabman
Kudos entered.
Spend an hour or so trying to figure out how to do it; until I search and found this. Seems so obvious it should be implemented.
AustinManinTown
This is still a good idea in 2019! Maybe it will be in the next version of TestStand. Pretty please 🙂
David C
