NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Add ability to search for instances of custom data types
Sometimes it is useful to be able to search for instances of custom data types. Unfortunately, there doesn't appear to be a way to do this in TestStand.  It would be really nice if you could search for instances of types in the Types window or perhaps through the Find/Replace utility:
6 Comments
Trusted Enthusiast
Trusted Enthusiast
What version of TestStand are you using? The latest version of TestStand already has support to match to type names with the "Find" feature which allows you to effectively find all instances.
Member RyanWright
I have been using TestStand 2010 SP1.  That's great to know that this has been implemented in the latest version of TestStand.  Thanks for bringing this to my attention.
Knight of NI Knight of NI
Knight of NI
It would still be nice to be able to initiate the search from the Custom Data Type tab by right-clicking on the custom data type definition.
Member RyanWright
Agreed.  At least they have added the capability to the Find/Replace utility, though.
Active Participant warren_scott
I have also had luck using Find/Replace in files.  Search for empty string, and set your filter (second tab) to only search within objects of type "foo" (whatever you are looking for).  Results take a little sorting through, but it can get the job done.
Oh yeah -- and don't forget to undo the "search only within types of XXXX" when you are done -- otherwise you'll be pulling your hair out next time you are doing a search and aren't expecting it to filter on only certain types.
Member RyanWright
Another helpful suggestion.  Thanks.
