When monitoring values within a loop in TestStand, it is often desired to only record step failure results. It would be useful to have a "Result Recording Option" of "Enabled On Step Failure":
This is possible through various means (SequenceFilePostResultListEntry callbacks and other custom code). However, I believe this would simplify TestStand sequence development significantly.
