NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
LVB
Add Progress Indicators During Pre-Load
Status: Completed
by Member LVB on ‎08-06-2010 01:13 PM
When loading large sequence files, TestStand does not display progress and appears to "lock up" both TestStand and the LabVIEW OI.  Sequences with hundreds of steps can take minutes to load.  Operators often incorrectly conclude the application has stopped respoding during long pre-loads.
I am suggesting to implement a responsive progress display, allowing the LabVIEW OI to proceed execution, and post the following UI Messages during step pre-load.
UIMessageCodes
  1. UIMsg_ProgressPercent–(Value: 11) TestStand step modules post this message to the user interface to notify it to update its progress indicator associated with an execution.
  2. UIMsg_ProgressText–(Value: 12) TestStand step modules post this message to the user interface to notify it to update its progress message associated with an execution.
20869i87D31F1755A9EB9F
Status: Completed
Now with TestStand 2012 you will be prompted with a Preload Progress dialog box when you open or execute a large sequence file that contains multiple code modules that might take a long time to preload. It displays a progress indicator along with the current sequence file, sequence, step, code module and module path as it preloads the necessary files. For more details on this new feature, check out the "Displaying Code Module Preload Progress" section in the NI TestStand 2012 Help under What's New in TestStand>>TestStand 2012>>New Features. Thanks for the feedback! Lars
Comments
by Member EMR on ‎08-09-2010 01:46 PM
I could see this as handy... even if progress messages aren't possible during the load, I'd appreciate more granularity in terms of 'starting to load' and 'finished loading' messages etc. (same for unload), I could code up some 'more realistic' fakery in my dialogs with that sneaky bit of info....
... along the same lines, it'd be nice if there were progress events during system startup too... but this might be a chicken-and-the-egg scenario.  For the GUI to show 'please stand  by server files/settings loading' it may require the server to finish loading in order to broadcast the events properly...  :-)
--Elaine
by Active Participant Jervin Justin on ‎04-15-2011 03:51 PM
Status changed to: Under Consideration
by Member Lars_L on ‎08-20-2012 04:57 PM
Status changed to: Completed
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Idea Statuses
Top Kudoed Authors
