It would be nice to be able to drag a sequence from the sequences pane over into the steps pane and have it automatically insert a Sequence Call Step with the dragged sequence selected.
It would be nice, but would cause problems for us unless we could modify it slightly --
Our use case for TestStand is such that client sequence files RARELY if ever use a out-of-the-box "sequence call" step type -- we use a customized "Company Sequence Call" step type that has a few additional special behaviors that are managed by our customized process model.
Right now it's pretty easy for users to get the right one, because the Right click -> insert step -> use type CompanySequenceCall is no harder than picking the out-of-the-box wrong one. If users are able to drag/drop and it inserts a "sequence call" step type, my users would start doing that we would have a lot of code that did not run properly. If we can configure it such that drag/drop an sequence onto this pane does action "foo" and I can configure "foo" to be "insert step type BAR with module XXXX" then I'm happy.
Exactly what I wanted to propose, too.
I would go even further:
Also allow drag and drop from workspace to insert a sequence call to the MainSequence of a sequence file in the project.
Background:
If you have to maintain a lot of small testcases for development tests, you have to create a larger set of independent test sets that should be executed together. There is currently no tool (I'm aware of) to do that.
Adding to that there should be button for LV Action step called “Load from LV” which helps in browsing of VI when developing the sequence.
Upon selecting that button it should list all the VI that are opened in LabVIEW and user should be able to select one of those. The VI path should get loaded for that particular step.
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
