NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Ability to Launch Version Selector from Error Dialog
When opening a version of TestStand which is not the current version, an error dialog shows. It would be helpful if this dialog included a button to open the version selector and/or a button to open the active version.
3 Comments
SteenSchmidt
N/A
Why not just be able to open the TestStand version you want without consideration of which version you had open last, like you can with LabVIEW? And in that regard dispose of the version selector alltogether, and thus also get rid of that error dialog - as I suggest here?
/Steen
sridar.m
N/A
This would help in reduce time and a handy feature
Elaine_R.
N/A
I'm not a fan of doing away with the dialog and having TS auto switch, as I've been burned several times in the past by launching the wrong version of LV by accident (or having a customer do so) and so triggering some unnecessary debugging / edits that shouldn't have been made etc.
But it would be nice if the dialog just prompted for 'hey, you currently have me setup to run in X, you're trying to launch Y, do you want me to reconfigure for Y or was that a mistake?"  where it could kick off a version select for me on an OK button press?  It'd make a nice usability improvement.
