NI Measurement Studio Idea Exchange
About NI Measurement Studio Idea Exchange
Have a new Idea for MStudio?
  1. Browse by label or search in the Measurement Studio Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea to the Measurement Studio Idea Exchange. Be sure to submit a separate post for each idea.
Top Kudoed Authors
User Kudos Count
1
Don't alter license.licx files without warning the user
I have a project file using .Net 4 (VS2010, properly update) which I opened in VS2013, upon opening with no warning all NI license.licx lines were removed with no warning whatsover.
This should never happen, if something is going to be changed the user should be informed what is happening, especially if it's going to break a build.
2 Comments
Member kvermeer
This happens to me frequently with VS2012, and only requires re-opening the solution. I haven't yet figured out what causes the license file to change, but agree that the changes are annoying.
As a workaround, make sure to add your .licx files to version control.  Then, when you go to commit your changes, the version control system will show the .licx file as changed, and you can just revert it back to the previous state.
Active Participant D-Cubed
We are tracking this issue with bug ID: 461933.
