NI Linux Real-Time Discussions
network drive automount help.
Hi,  I tried mounting a network drive in a shell and it worked :  mount -t cifs //10.10.10.10/d$ /mnt/photo -o username=username,password=password,domain=domain  However I want to automount it at boot up. I read that I have to enter it in /etc/fstab file.  I entered like this :   //10.10.10.10/d$ /mnt/photo cifs username=username,password=password,domaine=domain  It does not work, I also try other thing like :   //servername/sharename  /media/windowsshare  cifs  username=msusername,password=mspassword,iocharset=utf8,sec=ntlm  0  0  still not chance...  I'm using the good servername, username and password.  Thanks for your help.  Patrick
(3,254 Views)
Hi Patrick,
What versoin of the OS are you using?
If the command that you listed running from the commandline works correctly, then I think all that needs to be done is to reenable the network filesystem mounting script (/etc/init.d/mountnfs.sh) The initscripts are started or stopped based on their listed priorities, be sure to read up on one of the good articles on iniscripts, be sure to read one that targets sysvinit, not one of the other init systems (like systemd or openrc). Basically, you need to be sure that the mountnfs.sh script starts after networking is already up and stopped prior to networking being brought down.
Let us know if you need some more details or resources
(3,055 Views)
I will read on that tomorrow. Thank you.
I'm using an Industrial Controller IC 3173 that run Real Time Linux 64 bit.
(3,055 Views)
I've read a bit and didn't undestand exactly.
What I undestand was to put the mountnfs.sh somewhere in the rc(N).d folder after S01networking and adding a prefix of exemple S10mountnfs.sh to the file.
Didn't working like this in rc3.d
anytime I have network on the controller, I do mount -a and my network drive mount fine! I'm just not able to do it at startup.
There is rc0.d (1, 2, 3, 4, 5 6, S)
If you can help that would be great.
(2,812 Views)
