NI Linux Real-Time Discussions
Reply
File modification in Linux RT
Go to Solution
Highlighted
I have a problem in Linux RT when I modify a file by WebDav. When I change a file or overwrite it, it cannot be changed. For example, I changed /usr/local/natinst/share/TimeSync/tsm.json and I saved it then I opened it and I saw it had not been changed. I did that by downloading, changing then uploading, but after this process also the file was unchanged. How can I change a file in Linux RT?
Message 1 of 2 (160 Views)
Reply
Accepted by topic author Mmehrabin
‎02-20-2017 11:33 PM
Re: File modification in Linux RT
if you need to change minor modifications, like in a conf file you could use the shell built in editor.
VI. This allows you to modify the file directly.
How to Use the vi Editor
https://www.washington.edu/computing/unix/vi.html
Message 2 of 2 (125 Views)
Reply
