NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
scrib
Re: Welcome to the NI TestStand Toolkit for Large Application Development!
Anke,
In TestStand, the Tools pull-down menu, there is an item "Update Sequence Files..."
Joe
Member
AnkeS
Joe,
:smileyhappy:  thank you for the hint.
But honestly - a tool name like "Update Sequence Files..." is clearly a case of applied information hiding!
Best regards
Anke
Active Participant
Anand_Jain
AnkeS,
If you are currently editing the file, you can change the file format from Edit -> Sequence File Properties-> File Format comboBox
Regards
Anand Jain
Member
Coefster
In case any one is interested I modified the 'TestStand Large Applications Development' package to allow TestStand version 4.1.0 XML sequences to be viewed.
I can upload the package.  The user just has to simply extract the archive and maintain the same directory tree and use the web browser Sequence file viewer in lieu of the stand alone EXE viewer.
Bryan C.
Member
Thienai
Hi Bryan,
If you have chance please upload your modified one and share with us.  I currently have StestStand 4.1.0 which generate XML file that the current  'TestStand Large Applications Development' can't read.
Thank you very muck
 Thienai
Active Participant
The SequenceFile Viewer has been updated to view TestStand 4.1.x and prior Sequence Files. It can be found in the NI TestStand Toolkit for Large Application Development.
Note: TestStand 4.2 Sequence Files can not yet be viewed in the SequenceFile Viewer.
Manooch H.
Member
jap9711
You mention that the new update of the viewer supports sequence files saved in versions prior to 4.1.x. I have files saved in 3.5 that I would like to utilize the viewer with but I can not seem to get around the 4.0 xml requirement.
Any ideas?
James
Active Participant
My apologies James,
I failed to specify that it will read 4.0.x and 4.1.x Sequence Files that are saved in XML format. The Sequence File Viewer relies on Sequence Files being saved in XML format due to the parsing method it implements. Unfortunately, in TestStand 3.5 and prior, the option to specify your Sequence File format on disk was not available and TestStand 3.5 and prior Sequence Files were saved in .ini format.
Manooch H.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
