05-27-2008 12:21 PM
05-28-2008 04:09 AM
05-28-2008 12:49 PM
08-01-2008 07:51 PM
06-16-2009 06:21 PM
Hi Bryan,
If you have chance please upload your modified one and share with us. I currently have StestStand 4.1.0 which generate XML file that the current 'TestStand Large Applications Development' can't read.
Thank you very muck
Thienai
06-17-2009 04:20 PM
The SequenceFile Viewer has been updated to view TestStand 4.1.x and prior Sequence Files. It can be found in the NI TestStand Toolkit for Large Application Development.
Note: TestStand 4.2 Sequence Files can not yet be viewed in the SequenceFile Viewer.
06-29-2009 02:13 PM
You mention that the new update of the viewer supports sequence files saved in versions prior to 4.1.x. I have files saved in 3.5 that I would like to utilize the viewer with but I can not seem to get around the 4.0 xml requirement.
Any ideas?
James
06-29-2009 03:10 PM
My apologies James,
I failed to specify that it will read 4.0.x and 4.1.x Sequence Files that are saved in XML format. The Sequence File Viewer relies on Sequence Files being saved in XML format due to the parsing method it implements. Unfortunately, in TestStand 3.5 and prior, the option to specify your Sequence File format on disk was not available and TestStand 3.5 and prior Sequence Files were saved in .ini format.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
