07-26-2017 05:45 PM
I'm working w/ NI R&D to make this happen soon.
10-16-2017 10:05 AM - edited 10-16-2017 10:05 AM
Is there a reason that this is not part of ni.com/downloads or better documented? The compatibility chart says that this toolkit does not work with 64-bit LabVIEW. I would like to update the compatibility chart or create a KB about this, please let me know your thoughts.
Thank you,
10-16-2017 10:15 AM
It is because the 64-bit desktop version of the toolkit is only on the community and is not an officially shipping NI software product. If you have customers who request 64-bit version of this toolkit, please let me know.
10-26-2017 10:30 AM
Jeannie,
Please count me as a customer who uses this product and who would like to see it mainstreamed. I am only now switching our application from 32-bit to 64-bit LabVIEW because the 32->64 bit change can't be made until every single component is available in 64-bit variant. I would much prefer the Advanced Signal Processing Toolkit be equally supported on both platforms.
I am grateful to ZJ Gu and Yanhong at NI Labs for making it available, and saving me the task of recoding the functions we use in G.
Installation was largely smooth. I did get the following error:
The NI license manager showed that the toolkit was already activated (I had previously installed the 32-bit version of ASPT to see whether the supported version was secretly dual-architecture) so the error may be one caused by "product already activated". I'll try a clean install on another machine later.
-Rob Calhoun
12-26-2017 10:47 PM
iiiok
08-23-2018 03:21 AM
Dear all,
I have installed LabVIEW 2017 (64-bit) in my window, but I couldn't successfully install the advanced signal processing toolkit(ASPT).could you help me please?I wonder if you send me the ASPT installer.
Thank you in advance!
08-23-2018 03:41 AM
Hi samuelaa,
Please select the features to install.
Thanks!
Yanhong
08-23-2018 03:59 AM
Dear Yanhong,
Thank you so much for your early reply,unfortunately I did select that but still, it is not successfully installed
Regrads,
Samuel
08-23-2018 04:21 AM
Hi Samuel,
It seems you were installing the 32-bit toolkit.. Would you please check?
And you can find the ASPT 64-bit installer here https://forums.ni.com/t5/NI-Labs-Toolkits/LabVIEW-2017-64-bit-Advanced-Signal-Processing-Toolkit/ta-...
Thanks!
Yanhong
08-23-2018 04:39 AM
Dear Yanhong,
Thank you!Could you send me the actual 64-bit link of ASPT?
Samuel
