04-06-2012 08:25 AM
Just wanted to givet an update, we have reproduced incorrect DLL exports and should be building an installer today or Monday with the fix.
Joshua B.
PSE
Embedded Networks
04-09-2012 07:12 AM
Ok. I will plan to spend a few hours in our next sprint to try out the new driver. If I get any errors I will try to take a log and post that here.
04-16-2012 01:13 PM
Hi.
I just wanted to check on the status... any idea when I can expect a new setup with the fix?
04-16-2012 01:35 PM
Sorry for the delay. The fix is queue for virus scanning with the web content system right now. It should be up before the end of the day.
Edit: It is ready for download now. https://decibel.ni.com/content/docs/DOC-13164
04-24-2012 03:33 PM
HI Somaamos,
Did the b8 installer resolve your importation issues? Also, were you able to get an NI IO Trace capture?
04-24-2012 05:25 PM
Hi. I didn't receive any notification of the above posting... so I am just now downloading it. I will give it a test run.
03-26-2014 04:58 AM
just testing the RP1210 driver.
on the application, the Driver shows up, but it seems to be unable to scan the Network.
to be clear: I am not developing a own application, but i try to use it in an existing one; sourececode is not available.
is there any way to bring RP1210 driver to output some logfile, to see where it fails ?
Franz
12-07-2015 10:55 AM
Hello everybody.
Has anyone a LabVIEW code to use like example of RP1210.
I saw the examples on the links related, but it seens like C/C# code and I don't know how to use it on LabVIEW
04-05-2017 09:15 AM
Is the DLL suitable for use with Windows 10?
John
03-05-2020 12:10 PM
Is this supported for PCI/PXI CAN cards (8512, 8513)? Also, is the current version RP1210C supported?
Note: I am looking for something using C libraries and not Labview VI
