你好!你的问题应该是开机自启动的问题,也就是开发一个stand-alone应用
请参考
During development you normally connect NI myRIO to your computer with a USB cable. After
development is complete you can easily deploy your project as a stand-alone application stored on the
myRIO solid-state hard drive that starts automatically when you power up the myRIO; no USB cable
required. Study the tutorial Deploy a Stand-Alone Application (youtu.be/JXoJECRS-eo, 8:29) to learn
the step-by-step procedure to create a build for the real-time (RT) target, deploy the build as the startup
application, and how to disable the startup application, if necessary.
http://zone.ni.com/reference/en-XX/help/370622L-01/lvrtconcepts/building_rtapplications/
希望能帮助到您
