我用的是NI9215,第一个附件图片是我将AI0+和AI0-短路后的输出,并没有稳定在“0”。
第二附件是我从AI0+和AI0-输入7伏特的电压,可以看到有一个频率的噪音。
但是我用bandstop filter剔除掉55到65Hz的噪音,还是没有用,还是有噪音。
大家知道怎么处理吗?
谢谢!
大家知道怎么处理吗?
谢谢!
Hi
Did you configure the channel as Differential inputs?
Hi ian_fung
The 7 volts is provided by the power supply. I just connected the "+" in the power supply to AI+ and the "-" to AI-.
So I guess this noise comes from the power supply?
